Single 12" setups. What do some meter?
As far a DD,I am unsure about a 12" number but,I know that there is a guy that did 169.8 on a 9910 powered by 2 viper 2500s and a 170.8 with a single 9915 on 4 DEI 1000ds.
It was Nate Munson in a extereme class a couple of years ago I think it was the old termlab.
what meters, those def aren't TL measurements.
They definately have the possibility of being TL measurements, they could b in an extreme car....i know for a fact tht a single 10" DD did a 169-170(not positive exacts #) on the TL in an extreme vehicle. Also they could be TL in the port.
all the numbers that have been mentioned, are those all tuned high around 40-45 hz or what.....i would like mine to be around 30-35.......even if it doesn't do as high of a number.....maybe it'll still be slightly musical there.......
jason
fyi 40hz is not that high at all, and still can be considered musical, not all subs are the same...
Correct,like DD/AQ subs,all of the subs work great tuned to 40hz...which sound like it is tuned to 32-36hz I would say.In most cases if u tuned lower than say 38 hz of so u generally loud output and sq from the DD/AQ sub depending one the volume of ur box....HD3 in 6 cubes tuned to 35hz was wicked low!
I believe the 9512 is capable of high 130s, maybe low 140s in the right box. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
IIRC, horn enclosures are very nice but require a considerable amount more space then normal ported enclosures.
I'd like to see some responses because I've been thinking about trying out a single 12" DD setup myself. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif I hear they're suposed to be noisey little buggers but do they maintain moderate SQ for daily listening?
um, 9512's can hit well over 150 in the proper application
DD > all
Well i am gonna get my measurement and call Mobile Audio Concepts tommorrow......then i should know what is going on.......i would like a horn or t-line just to have......i can build a regular ported box myself but i want it to be d a m n loud not just loud.
jason
Here is a video of a Massive Audio CW12 in my jeep on a MTX 1501d doing a 145.8 on the termlab.
http://www.realmofexcursion.com/videos/MassiveAudio/cw12.1.wmv
DD > all
I wasn't sure, hence the //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif. I knew those DDs were noisy but ****. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
xhilr8n
xhilr8n
Dothan AL
tommyk90
vegang
vegang
