Single 10 for daily SPL?
Its gotta be loud as ****, sound good playing music (daily), and its only gonna be a single 10. Those aren't realistic goals for you imo.
ok, so then what would you use for SB1? The limit is (2) 10's, so what would you use in that case?
not a member on SSA, i'll just email jacob.
The NS v.2 is available. He said he may do some special order 10"s.
This of a NS v.2 15" not a 10" but...
(Quoted from Jacob Fuller)
Here are some T/S from the 15" D1 that I built for myself with 3 Hard spiders (stock stiffness):
RE: 2.09 ohms (D1 series)
Fs: 32.16 Hz
Qes: 0.48
Qms: 12.04
Qts: 0.46
Le: 2.86 mH
Vas: 47.05 L
BL: 20.07 NA
Cms: 53.44 uM/N
Mms: 457 g
The above with a very short break-in period.
After numerous 10,000 watt burps :
RE: 1.98 ohms (D1 series)
Fs: 31.78 Hz
Qes: 0.448
Qms: 12.20
Qts: 0.432
Le: 2.80 mH
Vas: 50.64 L
BL: 19.59 NA
Cms: 57.52 uM/N
Mms: 435 g
Spider seems quite stable in compliance after a tremendous beating -- of course we knew that from the v.1 Nightshade
i joined just to read it haha.
seems like a well built sub, but i wouldn't expect any less.
It looks like it won't be available for a bit longer, which would be perfect timing for me.
TREO Engineering | SSp Series Subwoofers
treo SSP, the VC can handle 500 °F which is why the brace is there because the slugs get hot and melt the glue, its rated at 1krms however due to the VC design it can take a hell of A LOT more
What are Treo's prices like? Always looked at them but idk anything about them cept they're sexy
apx 10? i ran one to 3 daily thrown 3kw rms at a single one before...
Same question^^^ what do they go for new/used?
You said this was a daily system, not competition. If you can run two 10's why are you wanting to do one?
And my point was you are asking a lot for a single 10, given the compromises needed to expect a competitive level of output.
cause it is fun to run a single 10" and see what can be done is why i did it. why ya need a pair? in a good install he could do low 140s and be tuned to 32hz...
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
484
755
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
945
bunkerking09
Current Status: Win
bunkerking09
Kansas City, MO
TaylorFade
    May 16, 2024
    May 16, 2024
