Single 10 for daily SPL?
not a member on SSA, i'll just email jacob.
The NS v.2 is available. He said he may do some special order 10"s.
This of a NS v.2 15" not a 10" but...
(Quoted from Jacob Fuller)
Here are some T/S from the 15" D1 that I built for myself with 3 Hard spiders (stock stiffness):
RE: 2.09 ohms (D1 series)
Fs: 32.16 Hz
Qes: 0.48
Qms: 12.04
Qts: 0.46
Le: 2.86 mH
Vas: 47.05 L
BL: 20.07 NA
Cms: 53.44 uM/N
Mms: 457 g
The above with a very short break-in period.
After numerous 10,000 watt burps :
RE: 1.98 ohms (D1 series)
Fs: 31.78 Hz
Qes: 0.448
Qms: 12.20
Qts: 0.432
Le: 2.80 mH
Vas: 50.64 L
BL: 19.59 NA
Cms: 57.52 uM/N
Mms: 435 g
Spider seems quite stable in compliance after a tremendous beating -- of course we knew that from the v.1 Nightshade
i joined just to read it haha.
seems like a well built sub, but i wouldn't expect any less.
It looks like it won't be available for a bit longer, which would be perfect timing for me.
TREO Engineering | SSp Series Subwoofers
treo SSP, the VC can handle 500 °F which is why the brace is there because the slugs get hot and melt the glue, its rated at 1krms however due to the VC design it can take a hell of A LOT more
What are Treo's prices like? Always looked at them but idk anything about them cept they're sexy
apx 10? i ran one to 3 daily thrown 3kw rms at a single one before...
Same question^^^ what do they go for new/used?
ok, so then what would you use for SB1? The limit is (2) 10's, so what would you use in that case?
You said this was a daily system, not competition. If you can run two 10's why are you wanting to do one?
And my point was you are asking a lot for a single 10, given the compromises needed to expect a competitive level of output.
bunkerking09
Current Status: Win
bunkerking09
Kansas City, MO
TaylorFade
