simple little build log
azimuth
funded*by*soros
9,662
Denver, Co
1.25 cubes @ 30hz for 10 inch sub (probably an alpine type E)
nothing big. selling on craigslist with a sub for 150$. assuming i stick with a cheaper sub like a type E or similar sub. i'll stick it in my truck tonight on my xtant a4004 and see how it sounds. done about 10 of these, so it should be fine. got the design from johnnydrama's post in the free box plans sticky. alot of nice plans in that thread.
sound deadener/undercoating. works well inside the box. not smooth enough of a finish for outside. this particular brand sprays on a little splotchy.
still have a little touch up to do, especially in the port opening. i'm gonna wait a couple hours before i spray more on. probably won't post any more pics, as this is such a redundant build
cheap enough for some one to enjoy, and it looks pretty **** good for 150 bux
think i should raise it to 200$? //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
people always low ball on craigslist so you will end up at around 150 if you put 200.
I went with those simply because they fit, the cutout is round, and the hole will take a 6.5 coax. Cutting a square hole in a boat for a speaker...
21
5K
I think you're going to find this is true across the board. Technology has come so far at this point that even the absolute rock bottom unit that...
I would run a pair of 15s in an suv.. or run 4) 12s
24
No Issues out of my CT Sounds amps..EQ, 6.5s. There is not one company out there that hast ever had a perfect QC run that I can think of.Hard to...
azimuth
funded*by*soros
azimuth
Denver, Co
JBLCAMRY
    May 16, 2024
    May 16, 2024
