Should this be enough for two saz-3500s?
add a second alt
Cant, this is a daily car so I need my ac. lol
nope. I run 2 d3100s, a xp950 and a dc spx 300a on a single saz3500... runs fullt tilt no prob, but two 3.5ks is stretching it...
Oh wow, reason I thought thatll itll be fine is because whenever I had my sundown saz-3500 at .5 ohm on my civic, it only dropped down to the mid 12s full tilt unless I played it for a long period of time then itll dip further down. That was with 2 runs of ofc 0 gauge knu wire, a single d3100 battery in the rear and the stock 80 amp alt. I know thats not the best voltage but I didnt think it was too bad for the electrical I have.
Btw, I also have a kinetik hc1800 in the front.
Are you competing? If not you would be WAY better off running a bit less power. Unless you want to invest significantly more money for a very minimal audible gain.
4 G31 Dekas and the 270xp with a bigger batt up front also. Assuming amps are at 1ohm each with imp rise you should be fine.
I ran 4 AQ 3500's at 1ohm each with a single 270xp and 12 batts. Could demo full tilt for 5-10 minutes NP...
myjaja
Audioque
myjaja
San Antonio, Tx Posts: 143,632 _____<^>*_*&l
myjaja
