should i worry about impedence rise with a daily set up?
talon2nr7588
ima be buying my amps soon, but what keeps getting me is will they put out rated power with impedence rise? my set up will be for daily and i will not be competing. should i even worry about impedence rise? i was thinking getting a kx2500.1 or zx2500.1 and run it at 2 ohm. then maybe later run it at .5 ohm and with imp rise it should around 2 ohms. what do you guys think? should i even worry about it?
Maybe a different amp? Well if you want to run it at .5 ohms. Depending on the subs(I dunno how much power they need or waht subs they are for that matter.) i would rather have it at 2 ohms.
i need at least 1500 rms per sub
You wont be able to audibly tell the difference in that 500W //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Just wire them at 2ohms and give them the 2500+ W RMS...in the end, it'll be around 2750W RMS...
i always thought that impedence rise went up more when competing, then when using test tones. since when using test tones it also draws more current, correct?
What in a box causes impedence rise?
gnomes......tiny little gnomes with axes that add unwanted electrons to the circuit and make the imp. rise occur........
j/k....loooots of things make imp rise happen....
if you can get to 1 ohm you'll be set man wit a zx or kx, my kx fucing loves 1 ohm. with a lil imp rise im probly right around 2 oms or more but still getting enough power out of it daily
talon2nr7588
talon2nr7588
Indiana
talon2nr7588
