should i use a divider?
If you run them in stereo, yes you will need a divider.
If you run them in mono, no you will not need a divider.
dork
I agree with the bracing idea plus if one sub goes down you can run the other until you get a replacement. But bracing is a great idea and I would do it if I had the choice.
dork
I am gonna let that slide...
Even if you build the divider its still a good idea to add bracing. And there will be no difference in having the divider EXCEPT....you will loose a little internal volume with the added wood inside the box.
The above is true when subs are run in mono.
P.S. If you set them up right in the first place the chances of one "going down" anytime soon is very slim //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
haha you guys are hilarious. thanx for all the advice. i think im just gonna go without the divider then. i dont think two 10s will need that much bracing. i was asking because i heard if they are i the same enclosure that each sub might not get the same wattage. but ifyou made it dual chambers each one would always receive the same power? also would i have to use two terminals instead of one if it was divided?
equal power has nothing to do with a divider and how much each gets. When speakers are wired together they get an equal amount.
As jack stated you will not need 2 seperate terminals.
ryboy2222
ryboy2222
ventura, ca
Johnny Drama
vegang
vegang
