Should I Trade It
If you want reliability get a 2 stroke. When it comes time to rebuilt a 2 stroke compared to a 4 stroke it is way cheaper. Plus they're way easier to work on. WIth a 4 stroke you've gotta check the valves, cam chain, do more oil changes, change oil filters.
2 strokes just mix the gas and ride
this seems to be my experince also.
i ride dirtbikes and have a kx that has about 3 years on the top end (2 stroke) and im lookin at about $200 to have it rebuilt.
i like a 2 stroke for track/jumping but i want a 4 stroke for trail riding.
^Yeah top ends are less than like 200 bucks
And depending how bad a 4 stroke is when you need to rebuild it
This is from another forum:
Let's see...I've rebuilt many 250fers.
Here's a rough idea of one wih a slightly green hue.
Piston kit (Wiseco) $180
Gasket kit (Cometic) $65
Valves (OEM) $35ea (Pro Circuit) $350 for a pair
Valve spring kit (Faction) $265 (Pro Circuit) $355
Valve seals (OEM) $45/set
Timing chain (OEM) $35
Timing chain tensioner (OEM) $80
Usually the cheapest parts total is in the range of $700-800 for a good top-end rebuild. This doesn't account for worn cam journals, valve seats, crankshaft, or valve stem guides. I've done repair orders up to $2200 if a valve broke.
change the oil and put gas in it, grease the springs and oh change tires about every 4-5 months . Never had a problem with my raptor besides when I went on deployment and came back the factory battery was shot from sitting with no charge for so long. Maintenance on a banshee will be a little more, just moping around on it will foul the plugs.
Grease the springs wtf??? Most guys I see with 2 strokes that are fouling plugs are usually morons that try putting bigger gets in to make them faster, or idiots that don't under stand gas/oil ratios.
2 stokes vs 4 stroke in general with maintenance, the 2 stroke might have to be maintained a little more, as far as replacing rings and or top end rebuild. BUT maintenance on a 4stroke is more expensive, since you have a whole added cam/valve train in the motor. Banshees are fast, but they are not THAT fast. It's basically the same quad with different color cosmetics for over a decade, so it they are outdated machines imo. Like someone said earlier, 4 strokes are easier to ride, or easier to use all the power, and have a considerable more amount of torque, which helps in chugging gears in the woods. FI is easier to maintain than a carb and more reliable (once it's dialed in you shouldn't have to tough it again), but when something goes bad with FI it's usually a pita. but but personally I know very little about FI.
IMO...
2 strokes>old 4 strokes
Modern 4 strokes> 2 strokes
When comparing older 4 strokes as far as reliability, Honda has the best durability IMO.
I would take a banshee over the newer 4 strokers. I just like the 2 strokes in general, but now in california they really came down on them so it's just better to have 4 strokes...
Banshees are no longer made either btw, idk if that's been said or not i didnt look at the thread. The hard part about maintance about the banshee is the dual carbs, but if you're good at setting them correctly then that should not be a problem. Lots of mods for the banshees too.
MY warrior is a 95 and im looking for about the same year banshee, id take a blaster too but id want money with it or it would have to have some money in it.
I might be alone in this but here is a few thoughts:
I never once heard the Suzuki Z400 or 450R get mentioned which is odd. I have the Z400 and love every inch of it. Their biggest drawback is the rare need for valve adjustment and that is only when ridden too hard for too long.
I have also owned 2 strokers and several other 4 strokes.
I ran a small but worked up and surprisingly fast Honda 300ex set for trail racing,
A Kawasaki KFX400,which is powered by Suzuki,A Warrior,Blaster and just today hopped on a 660raptor with endless mods.
My experience,personally: The Z400(stock for now) I own right now takes the cake. I can outrun Honda's 450R in mid/top end and even the Raptor I rode today wasn't enough to convince me I'd rather have it(although it is a great ride)
Sure,it was faster at top end but it took forever to wind it out and there just wasn't enough extra power for the extra 260+/- cc engine to make it worth it for a hard to trail ride machine
To get back on topic,any reputable 2 stroke is a fun ride so long as you don't plan on lugging it or constantly hitting steep climbs.
For what amount of riding you submitted,I'd say a 2 stroke or a Suzki400/Honda 400ex would get you the most for your money.
BTW,getting a Suzuki 400will allow room for immense modification. They are moderately cheap to bulk up to and above the limits of any current 450R breeds out there...for cheaper than buying a stock 450R of nearly any model.
I might be alone in this but here is a few thoughts:I never once heard the Suzuki Z400 or 450R get mentioned which is odd. I have the Z400 and love every inch of it. Their biggest drawback is the rare need for valve adjustment and that is only when ridden too hard for too long.
HMM Suzuki Lover, imma have to think about that one as well.
Johnny Law.Lulz
Banned
Johnny Law.Lulz
Virginia
jeepdriver001
