Should I Short the Voice coil or NOt ?
yes i did sell it,,,,,,,,,,,,
I came on here from ppl that arent retards who actualy know that you can do tis 100% without a problem and asked a question i never asked if i sohuild or shouldnt run only one voice coil, because i know I CAN i have it hooked up like that right now and in my car and it sounds great
Anyways
Anyways
lol, then do it and STFU.
KTHXBYE
I would either sell your sub or amp and buy a different one. Unless you want to try running the amp at 2 ohm and see what it does. But personally i would rather have 2 pieces of equipment that i was fully using.
well i never wanted to run 1000rms into the sub anyways i wanted half
well actualy 600rms is wat the amp actualy does at 4ohms bridged which is good enough
like i said i do know for a fact you can just use the voice coil 1 and thats it
so why would is ell anything if it works fine that way
Hey idiot i AM doing it but the reason i made this thread is because i didnt know if i should short the 2nd VC or not
goof
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
im telling you short it.
you will have much better excursion and both coils wont have to break in just 1 will
if you want to short one of the coils just plug it into a wall socket it will be much quicker that way.
Anyways
As long as you are aware that running one coil also changes the thiel smalls to your woofer and adequately account for this with box design....
You should be banned for being a ****ing idiot.
Look at your owners manual, and every other ****ing owners manual of a dual voice coil sub. They specifically say, you must hook up both voice coils.
But do your thing man.
YA IT ONLY SAYS THAT BECAUSE THE SUB IS RATED 1000rms at DUAL voice coils
id you only use one coil you be only geting 800rms or and if you pump 1000rms into a single coil then its not good thats why it says that you shouldnt do that
JUST FOR THAT REASON
YA IT ONLY SAYS THAT BECAUSE THE SUB IS RATED 1000rms at DUAL voice coilsid you only use one coil you be only geting 800rms or and if you pump 1000rms into a single coil then its not good thats why it says that you shouldnt do that
Im not going to personally bash you but if you think that is the only reason subs have dual voice coils you probably shouldnt be anywhere near audio equipment.
There is also lots of false information on the internet. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
BrokenJaw
BrokenJaw
Ontario
silvercookie
