I have 2 SSA Dcon 10's those are 400w SVC subs, I have currently a JBL GTO 751-EZ. Which does 750w at 2 ohms, which i do understand is fine.Steve Meade also tested the model amp below mine on the dyno and certified it pushed out well over what it was rated. My problem is that amp has no Sub Sonic filter and im running the subs in a .75 cu ft box tuned to 42hz at the moment but will soon run them in a 1.22 cubic ft box tuned to 37hz. Both of which are ported boxes. I love the JBL amp and it has a function that helps me set my gains which is cool and i got it at a good a deal and only paid $150 for it and did not realize i need a subsonic filter. This amp is small which is good because it needed to fit under a dodge ram 1500's seat, so it a perfect amp except for the fact of the lack of SSF. Another member referred me to Hlabs in choosing a Subsonic filter and i have found one "Crossover Harrison Labs Pfmod TM Subsonic New | eBay " this filter is a variable filter that can be set to multiple settings. The problem is its $44 and is only at a 12db octave slope. So that brings up my new question, do i keep my current amp and just spend the $44 on that SSF
OR do i send the amp back (that cost money) and buy a different amp maybe one that is better?
If you think i should send it back and buy a different one, what would be a good one?
It needs to do 800w+ @ 2 ohms
Needs a SSF, hehe
and it needs to be small enough to fit under a seat ( i can list dimensions later, but it can be a bit bigger that the JBL's, LxWxH 8-3/8 x 9-11/16
x 2-9/16)
The soundqubed amp seems to be what i am targeting Q1-1200D Amplifier
It has 24 db octave slopes on all the crossovers, does 800w+ @ 2 ohms, and the bass knob comes with a cool clipping indicator, i just havent heard anything about Soundqubed
I haven't listed a budget because i don't know where to start, i have 200$ for sure and don't mind buying from eBay or Amazon. I have found that if i find a amp somewhere look at on those websites and im bound to find it cheaper.
Thanks
Needs a SSF, hehe
x 2-9/16)
Thanks
