Should i go with this? fi bl
tripphxc
Okay, I think i know what im going to go for...
well not really but an idea,
this will be going inside a jetta
So, Two fi bl 15"
If i were to do this, would i need to upgrade any electrical shit in my car?
or just a good amp?
also, what modifications would i want to add on to the woffers when purchasing them?
like the dual, cooling, spl or daily, ect...
idk what that means.
and are the btl ALOT louder then the bl?
thank you
I don't think a pair of 15s ported will fit in your trunk.
And yes you will need to do the big 3, good batt up front, and a bat in the rear for your amp.
So, Two fi bl 15"
or just a good amp?
thank you
in descending order
Code:
So, Two fi bl 15"  [b]Nice[/b]
or just a good amp?  [b]Good Amps and Upgraded electrical a must[/b]
like the dual, cooling, spl or daily, ect...     [b]Yes, yes, and daily or spl is pretty self explanitory bro.
[/b]
also how are you going to fit a box in a jetta again?
Ahhh. i just want to make a decision... so im guessing 2 15's wont fit in my jetta...okay. what about one fi bl 18? ? :/
bro simple math...
18=18
12+12=24
get two 12's. more cone area. should be able to fit a box back there
give us max dims of trunk and trunk opening
Cargo Area Dimensions DetailsTrunk Volume (ft³) 13.0
That is utilizing every inch of your trunk. You need to allow space around your box so you aren't cutting the sound off from the rest of you vehicle. I would just go with a single 15'' if I were you.
bro simple math...
18=18
12+12=24
did you really just say that? //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh:
1 18 has more cone area
did you really just say that? //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh:1 18 has more cone area
x2 was about to say something lol here is a vid of my 2 15 fi bls on my powerbass xa3000d only pushing like 2000 watts case of our temporary install/ shitty electrical..
So if i were to go with 2 12's BL everything should fit in my trunk... correct?
well if this is correct then im going with these. hopefully i wont regret it.
what amp would i want to use to power these the same amp listed before?
and where would i get all the wires
and finally
what configers should i do to them woofers?
like cooling, dual 1 or 2?
hers the list
Ohm:
P Chamfer:
Cooling:
Flatwind:
Daily or SPL:
Extreme Lead:
Universal:
Dustcap:
bro simple math...
18=18
12+12=24
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif math fail? Pi*R^2 = cone area
tripphxc
tripphxc
New York
tripphxc
BP1Fanatic
BP1Fanatic
