I was reading on forums here and one said I should do "about 3 cubes if its sealed sounds good and about 4.25 cubes ported tuned to about 35 HTZ. i have had cvrs alot and ran sealed and ported. i have found these two sizes sound best for the 15s."
So which one is better sealed or ported.
and what would be the best program to mess around with box design to see which one would hit the hardest?
one more question. What is htz, does it mean that you will have a bigger box or what does htz really do
I'm not going to build the box I just need the box design to give to a friend to build
Like the deminstions, sizes, because I have no idea what 3 cubic feet would be. (just curistite on how big it will be)
The reason I am asking is because the kicker website says
Min Rec Sealed Box Volume (CU. FT., Liters) 1.8, 51
Max Rec Sealed Box Volume (CU. FT., Liters) 5.2, 147
Min Rec Vented Box Volume (CU. Ft., Liters)** 3, 85
Max Rec Vented Box Volume (CU. Ft., Liters)** 5, 142
So it doesn't say what would be the best to use, to hit the hardest
and yes I am a noob asking for professional advice
Thank you
Thank you
