should i go sealed????
if you have the space go ported they allow for lower frequency response by means of tuning. if you re laking space then go sealed. to get really low youll need a big sealed box. how big of a sealed enclosure depends on the t/s parameters of the sub.
i have beening looking for on the internet for hours!!!
and cant find a calculator on the web where i can get the box sizes for a dual sealed box
single is easy find
can anyone tell me of a webite that has one....
my subs require 1.5 cubic feet each if someone will plz do the work for me
thx for your help
just build it big pimpin. make it like 3.2 cubes and call it a day. Use 3/4" MDF board. Use wood glue on all of the joints along with screws and make sure to seal the inside of the box VERY WELL. I prefer silicone, but let it cure for at least 1 day. Use a router or a jigsaw to cut out the holes and mount the subs in there. Best to get wire terminals but for a better connection drill little holes in the side of the box to run the speaker wire through then silicone those also. Carpet. Crack a Brew. Sit back and enjoy.
if do what u said drill through the box and hook it up direct to the sub will i be able to tell a difference in perforance then if i used a terminal cup???
I always use terminal cups unless you are a real serious spl comp guy. Take a DMM voltmeter and measure the signal strength with a terminal cup and then do it without and let me know the difference. I am always screwing with my setup and like the ease of using a terminal cups and bananna plugs.
http://www.sonicelectronix.com/item_2995.html
http://eddie.dyec.com.tw/diy-products/banana/banana_image/banana.jpg
dflw_99
Kicker Ownage
dflw_99
OPP,AL
DFW40
