Should I get a Orion 2500D, or a Kicker 2500.1
snb778
blaugh!!!!
Which one is the best for the buck....is the kicker worth the extra 100 bucks? Is it as compatible and Stable as the 2500D? I am going to get one of these for sure, so any help would be great. Thanks
Also does anyone know a good site to get either one of these for cheap...or if anyone here has access to get them that would be great...i'd throw you a few extra bucks for a hookup!!
recommended at 2 ohm, but has been ran down under 1 ohm daily with success.
I have used 2 1250.1 kicker amps and done them at some really low impediance.
also for about a week ran a 2500 kicker at 1 ohm not a single problem... it did get alil hot tho
you can find two kx1200s that will give ya the same power for under $600 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
cant say which amp is better since i have no experiences with kicker. The orion is a hell of an amp and has been run .5ohms daily by some people on this forum. I will be wiring mine to .75 ohms. The wc5000d is pretty cheap on ebay and is the same amp theres pics of the internals on termpro.com
egg
if your asking if a kx 2500.1 can be ran at 1 ohm you shouldnt be buying one. im surprised nobody has said that yet. you would have to send it some serious voltage to be able to keep it there, and like ecko said it will get hot.
snb778
blaugh!!!!
snb778
ex. Los Angeles, CA
BassAddictJ
