babsuhl81
I'm deciding on an amp. Should I get a bigger amp that can run 1 ohm but run it at 2 ohm? Will it last longer than if I get a smaller amp and run it at 1 ohm?if I run the amp at a higher ohm load will it last longer? For example I'm looking at running a hf brz 2400.1 @ 2 ohms. 1700 rms or a brz 1700.1 @ 1 ohm. 1700 rms
