Do all batteries charge the same? No If you have wet flooded cells they will charge harder than AGM type cells. If a battery is a heavier load than another to begin with and takes longer to charge there is a difference. An alternator in any 12v system though has to be powerful enough to maintain a charge, depending on the battery the charge maintained should be at least between 12.5 to 12.8 volts. Also in many situations it is difficult to get an alternator that puts out enough power not to mention enough power while it is hot (have seen many a high output alt lose 50 or more amps after it has gotten warmed up from a few hours of driving) To correctly build a system that will last it must have both a good alternator and battery/batteries. 2200 watt amp is alot of power 2200w/14.4v=152.77 amps draw if it were putting out 2200 watts and were 100% efficient which its not but at the sametime I doubt you will be drawing 152 amps often at all (more than likely between 70 to 130 to music)but at the same time the car itself is going to need power as well (40 to 60 amps constantly).
