Umbra
Hobbyist & CA Tenderfoot
I recently picked up two pairs of 6x9s to replace the shot OEM speakers in this minivan. Before I pried open any panels I had envisioned just dropping them into the stock spots. I'd treat the doors a bit, run new wire to them, and amp them. I'm still going to do that in the front because there's not much room to work with, the stock location is reasonably high, and the door has some substance to it, so treating it isn't going to be a massive undertaking. However, then I took a look at the back:
The doors (there's one on each side) are mostly air, there's virtually no bracing, the speaker location is at ankle level, and the doors don't have that power closing function - they need to be slammed (which I can't imagine is good for speakers).
Realistically I can treat the hell out of it and maybe even move the location higher so it's actually heard, but I wonder if I wouldn't be better off sticking them in boxes facing upwards, or at an angle towards the rear passengers. I could move them around to any row on whim with long enough wire, even outside the car, and I could pull them temporarily if I absolutely needed to maximize space (though in the door that's a moot point). I could make it either sealed or ported (though I've never put a 6x9 in either). I bought them used, but I found the original grilles on eBay so I don't have to worry about them getting accidentally kicked in. Aside from acoustics, the only real issue is a slight decrease in foot space.
Really the biggest thing, and probably what I should've lead with, is how would they sound boxed? The fronts are going to be in treated doors and I'm going to have a sub in the center console for low end (probably one ported 8", but possibly a pair of 10"s), so I don't need to force sub bass out of these. If I could use them for midbass and up that'd be great. The only true way to figure out which method is best (door, sealed box, ported box) would be to construct all of them and test them, but I don't have the time, money, or desire to do that right now.
TLDR: Should I box (either sealed or ported) a pair of 6x9s probably originally intended for a parcel shelf instead of sticking them into a crappy door, or should I treat the hell out of the door and put them there because that's what they were intended for?
Thanks for any insight and opinions you're able to provide.
