should i amp the infinitys??
  • 2
Doberdad
gb wi
i just bought a pair of INFINITY 6953i 6x9's, i have a rockford 300s amp, what do you think, should i amp em? im puttin them in with 2 re se's run by a hifonics 1500d. those 6x9's can get loud enough right? should b getting them any day now
is that amp too much for them?
do they have a lot of bass if you just use them alone?(6x9s, no subs)
will i have to turn down the xover when using them with the subs?
they have okay bass if they're not amped, but the bass and everything will be alot better sounding if they're amped. Won' distort as quick either. If you put your settings right they will have pretty good bass for 6 x 9 s. No that amp isnt too much for them.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
Have you check to see if the prefab would fit...
13
For the sub you want to run.. The 700.1 will be more than enough power and enough Head room for that sub. For the Price? And the sub you are...
13
Your skar amp will catch on fire if you go full power?
I'll suggest a JP8 amplifier. I believe you can wire your sub to 2 ohm. It's Dual voice coil 4 ohm, correct? JP8 @ 2 ohm does 900 watts.
Doberdad
Doberdad
gb wi
alove_85
    May 18, 2024
    May 16, 2024
