Should an accessory fuse work when the car is off?
  • 4
crreed55
CT
I'm trying to install a PA System, and from what I've heard, if connect the positive wire to an accessory fuse in the fuse box and ground the negative, it will not drain the battery since it will turn off with the car. However, I tried this today and it still worked, even when the car was completely off. I just don't want to bolt it in to find out that it's draining the battery and I have to fix it.
Will it be okay or do I need to install a toggle switch?
Depends on the vehicle. Accessories like cig lighter don't turn off with ignition. But the radio circuit will. Keep poking around and you'll find an appropriate circuit to use.
Many vehicles made in the last 10 years or so are using a data system to trigger accessories, and the power at the interior fuse box is constant at all times. This includes the radio fuse, which used to be the go-to fuse to tap to add a small accessory.
Then how do I install the toggle switch?
The Speaker has the negative/positive wires. The toggle switch has the negative/positive wires. How do I power the speaker with a positive/ground AND hook it up to the toggle switch??????????
Speaker? You said you were installing a PA system. Wire the + power wire to the switch and the other switch terminal to the PA power input.
The CT's are nice, That Sundown is a a frik'n beast!
859
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
716
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
836
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
crreed55
crreed55
CT
trumpet
    Jun 1, 2024
    May 31, 2024
