Setting Rainbow SLC X-over questions
whitemdx
Hi,
Got my amp finally running after using an LOC. Hooked up the Rainbows and starting to tweak my system (70w x 2 @ 4 ohm). I have several questions for the SLC:
1st) The x-over have the pin that have -6. -3, 0dB level, is that the attenuation of the tweets only? or for both the tweets and the woofer? I have the woofer installed in the factory door location and the tweet are in the fatory location as well (right at side mirror level).
2nd) the halagen bulb in the X-over, when it lights up, does that mean that there's too much power to the tweets?
3rd) when I turn the volume all the way down, i noticed there's a hissing sound coming out of the tweet, but not the woofer. Is this normal? I might play around with the polarity to see if I have my connection right.
I've haven't turn it up yet, because the manual recommended 10 hrs break in period.
Thanks.
crank them screw the break in... the will break in and sound better but you wont blow anything if you are smart.
1. tweet only
2. no clue
3. try turning the "high" down a little bit.
whitemdx
whitemdx
SoCal
6spdcoupe
