Setting Gains
Two ways to go about it. One is to set the gain on the amp as low as possible and then use the output level control on the crossover to set the amp output. The other option is to set the output level of crossover to 2-3v using a test tone and then set the amp gain as normal. Depending on the components in question either may be a better solution.
jerryrobinson
jerryrobinson
chicago IL
helotaxi
