Setting Gain CORRECTLY
BEEKAY
US
Can someone explain to me the correct way to set the gain with a DMM? I understand the basics but I had a question. So I know that all of your EQ settings should be set to neutral when setting it. What about a bass knob? Should that be turned down all the way too? Once the gain is set is it safe to turn the bass knob up without clipping?
NO, I recommend not using bass knobs... but if you must..... tune your system with it turned all the way up. this way when you have the knob cranked it's not sending a clipped signal because it was all the way up when you set your gains.
Makes sense, thanks for the advice.
What type of amplifier is it?
If you are setting gain with a DMM, you should measure AC Voltage at the speaker outputs on the amp. You want to turn up the gain until you see a specific voltage.
E = Square Root of (P x R)
So, 500w X 2ohm, then take the square root of that.. = 31v.
Turn up the gain until your DMM shows 31 volts. Thats probably as accurate as you can get without using a DD1 or Oscilloscope
BEEKAY
BEEKAY
US
BryceHinton
