separate ground for caps?
  • 2
d audio 450
Registered User
some of the guys at best buy dont know what they're talkin about, but i think some of them do...i was told that when you hook a capacitor up it needs its own separate ground wire- can somebody verify this with possibly and explanation why? i cant think of why-
thanks
-pat
A capacitor is just like a small car battery, except that it charges and discharges faster than a normal battery. You hook up continuous 12 power to it straight from the battery. You connect 12 power to the + terminal on the cap, then you just put another connector on the + terminal and then take that straight to your amps. Then the - terminal gets its own ground wire that connects to ground on the same spot on the chassis as your amps ground wire. The capacitor is just inline with the amps main power wire.
Understand?
ok- i think i misunderstood the guy at best buy, i thought he was saying you needed to ground the capacitor in an entirley different spot and all...definetly thanks for the clarification appreciate it
-pat
If you can have different things on the two original screens I’d want to believe a compatible hu having the features you want may be attainable...
4
810
I'm guessing that's what it is. There's not a lot of room back there.
12
It’s nice having a test bench. That one is nice and clean! I don’t have pics of mine but mine is built all out of wood with carpet top and all...
16
In the following order: DOWN4SOUND JFX653S - 6.5 INCH 3 WAY CAR AUDIO SPEAKERS - I did a good listening of these and was pretty impressed. It...
20
3K
Yeah I saw a lot of that when doing those installs as we also did surround sound system wiring as well. I always ended up being the doing it as...
11
d audio 450
Registered User
d audio 450
Pa Philly area
d audio 450
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
