second battery needed
ok I think that's what I will attempt to do.
would it be ideal to just get a new xs power or better battery and use the red top up front aswell with amps run off that?
once again much appreciated
ok I think that's what I will attempt to do.would it be ideal to just get a new xs power or better battery and use the red top up front aswell with amps run off that?
No. Sounds like your red top maybe on its way out
get te d3400 xs ' as main battery and the red top to power your amps ' but yea your red top might be on its finals have you charged your optima?
No I've had it about 2-3 years no issues,I just want my headlights go stop dimming etc.
Thanks guys
Thanks guys
2-3years can drain the capacity of the battery.
I'd have it load tested.
It will have increased resistance inside if the capacity has decreased. If you add another battery to the system while using that battery, it could rob power from the other battery constantly which will decrease the lifespan of the batteries and put more stress on the alternator.
2-3years can drain the capacity of the battery. I'd have it load tested.
I will definitely get it tested before adding my new battery. Thanks for the info bro, trying to find a used ish one to save a bit , if not I'll be buying brand new prob
I have a 2018 f150, looking to keep factory head unit, not running a dsp as this is budget build. I have a t harness, skar doors, amp and subs...
So, why the fukk is the pedo replying to me? He started the shitt again and I am responding. What don't you understand?
75
9K
361
cbuts
cbuts
canada,ont
cbuts
