Second battery draining first?
When you are measuring your batteries are you disconnecting the rear battery
and measuring each by itself and giving us those numbers?
ie:
Disconnect the rear battery, measure it.
Leave it disconnected, walk around to the front and measure the front one.
no im not, im just leaving them connected and measuring them..
Disconnecting the back would be an involved process. I have like 4 cables connected..
not to mention a little dangerous since i havent fused the power wire yet.
If you haven't disconected the battery's from each other before you test them your getting a combined voltage reading when testing either battery. That is why the voltage is the same at both batterys.
microhaxo
microhaxo
MINNESOTA
bulldoggg
