sealed vs ported debate. who is right
Onebadsrt
k so me and some guys that are helpin me build my box have a on going debate between which is better, we all agree that sealed does produce a little better SQ, but heres the disagreements.
1 says ported will sound awful with 3 750watt subs and that he can make a sealed box almost as loud and still hit low notes...... what do you think about that??
another is the oppisite that ported will still have good SQ and be MUCH louder than sealed could ever be. he swears at least4-5dbs. do you agree??
both these guys do audio for a living, im just in the middle tryin to figure out what to do lol
usually for subwoofers that are build to work in both
a ported enclosure will yield less power handling, but a 3-4 dB gain in spl output
ported enclosure are all about efficiency. Get as loud as you can, for less power. (as the port works like a passive radiator)
a badly designed ported box will sound worse than a sealed.. a well designed ported box can come close to amtching the SQ of a sealed with higher (lower) output.. also depeneds on the sub, car
also sealed can usually take more power, as long as thermal limits arent in the way... a ported box will bottmo out easier below its tuning freqency
Not matter of whos right and wrong IMHO.
If you want a little more SQ and tight punchy bass, go sealed. If you don't have SQ in mind, the ported enclosure will be a little louder, but still retain a small amount of SQ, depending on power, subs and box.
But the ported will be louder, now 4-5dB's...? Maybe, all in the box.
In that case, you should go with a ported box to house the 12s, assuming you have the room!
That is the other advantage to sealed enclosures because they usually do not require as much space as the same subwoofer would require in a ported enclosure.
Another plus to most sealed enclosures is that they have a gradual rolloff on the low frequency curve versus ported enclosures that usually flatline below the port tuning frequency.
Yes, but for a driver designed for both enclosures, the sealed roll off will begin at a very high frequency; where a vented enclosure can be tuned for extremely low roll off
True... I have seen some enclosures for 10" subs that border on 3.5 cubic feet (net) with the port tuned @ 23 Hz. They will play down to 20 Hz with no problems:eek:
That issue can be alleviated somewhat by going with a very large enclosure, lowering the Qtc //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
one of the things that = sq is having a flat response, meaning every frequency is reproduce at the same volume. thats why ported are usually inferior to sealed when it comes to sq cause they usually have a peak in the frequency response which is why theyre usually louder overall
heres the in car estimated frequency response for JL Audios 12w6v2 in sealed (yellow) and ported (red) in recommended size and tuning boxes
Ported 5 cubes net, tuned at 30Hz, 72sq^in of port area (6"x12" x 35.75"deep L-port)
and your set.
The ported guy is right, in the entire 25-40hz range you should see at least a 4-5db increase.
The box size is your major consideration. If you can fit ported, go for it.
what program?
edited......me = stupid for not reading scales:crap:
and also, look at the response in the most common musical range. the lines are very similar except the ported is louder
Onebadsrt
Onebadsrt
ellijay, ga
audioholic
vegang
vegang
