sealed sub box internal volume?
bradl79
NLR
Ok i made a sub box that the outer dimensions are 15.25D x 13.75H x 13.75W which i calc is about 1.19ft^3, i am looking at getting a sundown e v2 12" and recommended ft^3 is 1.0ft^3 sealed and displacement is .12ft^3 so will i be fine at 1.19ft^3
the box it self os 1.19 after sub you'll be at 1.07. your good
Yes the internal volume is before sub, the dimensions are outter with 3/4 mdf so internal is really 13.75 x 12.25 x 12.25, thank u
If you experience any air leakage from the screw holes.. adding Clear or the color of you choice of Silicone works just fine after a 24 hour cure...
10
Most ported boxes will be 1.75-2.5cubic feet of airspace. That's just a base requirement. Sealed will be .8-1.25. That said ported has the...
  • Locked
If you're available... please dm me. I'm interested in chatting about this box. Hopefully it's still for sale. Thankyou
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
I dont think this forum is letting that link work. It keeps changing it to a link to this forum. Try this. Just change the dot...
10
bradl79
bradl79
NLR
bradl79
    May 12, 2024
Brendon Jenness
    May 11, 2024
