bradl79 10+ year member CarAudio.com Elite 1,431 0 NLR Feb 27, 2015 #1 Ok i made a sub box that the outer dimensions are 15.25D x 13.75H x 13.75W which i calc is about 1.19ft^3, i am looking at getting a sundown e v2 12" and recommended ft^3 is 1.0ft^3 sealed and displacement is .12ft^3 so will i be fine at 1.19ft^3 Click to read more...
C1500martin 10+ year member CarAudio.com Veteran 3,399 1 Cali Feb 27, 2015 #2 the box it self os 1.19 after sub you'll be at 1.07. your good
OP bradl79 10+ year member CarAudio.com Elite 1,431 0 NLR Feb 27, 2015 Thread Starter #3 the box it self os 1.19 after sub you'll be at 1.07. your good Click to expand... Yes the internal volume is before sub, the dimensions are outter with 3/4 mdf so internal is really 13.75 x 12.25 x 12.25, thank u
B Beatin2door Junior Member 17 0 Clarksville, Tn Feb 28, 2015 #4 If you end up with 1.07 after sub i'd say you did a good job gettin the box as close as possible to spec roll with it.
OP bradl79 10+ year member CarAudio.com Elite 1,431 0 NLR Feb 28, 2015 Thread Starter #5 Should i leave is or put some pollyfill in it?
