sealed or ported?
chinxtaboi
tx
runnin two 12" kicker compvrs.... powered by MA audio 1000 watt amp
should i go sealed or ported?
i want deep bass yet sumwhat clean crisp bass... and im not gonna be upgradin subs anytime soon.... so what should i do....
o and its all goin in the back of a yukon denali.... im currently runnin ported (soud good) .. but wonderin how a seald woul work
gonna spend lotta time on this box... itll have an amp rack and all...
thanks
Originally posted by chinxtaboi runnin two 12" kicker compvrs.... powered by MA audio 1000 watt amp
thanks
The quality would be better, if yout current ported is not made right...
I don't know if you'll be able to distinguishthe audible difference, but one thing's for sure, it won't get any louder...inf act, it might even get a bit quiet...ask Jmac for the specifics...
well actually it gets loud as hell.... so im hopin if i run a sealed enclosure... i can tone it down a bit and get sum sq
but i still wanna hear from the box gurus
Originally posted by chinxtaboi well actually it gets loud as hell.... so im hopin if i run a sealed enclosure... i can tone it down a bit and get sum sq
without too much info on the boxes...thats pretty much exactly what you should expect.
well im runnin 2 12" old skoo compvrs ...
how low is low.. for a ported enclosure.... right now mines bout 35ish
im hopin to making to separate boxes with an amp rack in the middle...
suggestions?
thanks for all the input so far:D
wut were your port dimensions.... was it stickn out the box?
and does it matter which way your port is shooting?
well i guess ill jus stick with the sealed and leave the fancy ported design stuff to the box masters....
i hope i dont lose to much boom going from ported to seald... and gain sum sq
thanks for all the help:D
I scrolled thru there trying to find TS specs and must have missed them or they weren't displaying. Anyway, looks like 2cuft tuned to ~35hz was a...
For what it’s worth… I picked up a mti stage 4 or 5 for around 900.00. Loaded with jl tw3 it’s was 1995.00. Which is a good 1k off what I would...
Assuming the taget curve is the same they will sound very similar. 2nd and 3rd order harmonics might be different but are offer hard to even hear...
😂😂 I actually have a CNC at my shop (I make drone parts for a living). It’s just that I got intimidated by all the tuning (equipment I don’t...
18
Kodas like big sealed boxes and can't handle power. I shredded the surround on my 8 in .4ft³ and 350w My 10s on 1000w for the pair one coil...
286
chinxtaboi
chinxtaboi
tx
chinxtaboi
    May 31, 2024
    May 24, 2024
