OP your first sentence says exactly what you want- good sq without sacrificing loudness. Thats what a ported box will do for you. Tune it to 30-33hz and use bracing for rigidity and it will be louder and sound better than any sealed box you could put them in. Sealed boxes choke 40-60% of output compared to a ported box. Sealed boxes are like running a restrictor plate on your subs. You will have to have a ported box made for you. The pre made ones that you can buy are too small and tuned too high so they never will sound good.
Thanks both of yall for all the input! Do you think If I wanted a good mix of SPL and SQ (leaning slightly towards SQ) 33 hz would do it, or should I go lower?You can still get a flat response curve with a ported box. The size will vary depending on the woofer. I'm doing a box for an MTX Thunder 8000 15 and its 3cu/ft tuned to 30hz and the response curve is just about flat. A perfectly flat curve would be 3.44cu/ft tuned to 27hz, so the ripple is very very small. Most woofers need a stupid large box and low tune to get a flat response curve. My Boston G5s are tuned to 33hz and have an fs of 28hz and I can play down to 20hz without unloading and my sharp rolloff begins around 25hz. According to winisd my f3 is 33hz.
Op said he doesnt want to sacrifice output and thats exactly what a sealed box does.
There are plenty of people on here who run single woofers on
This forum is slightly biased towards spl, so if you want true sq discussions, go hang out on diyma.
kthxbye
hahaa diyma ftw!You can still get a flat response curve with a ported box. The size will vary depending on the woofer. I'm doing a box for an MTX Thunder 8000 15 and its 3cu/ft tuned to 30hz and the response curve is just about flat. A perfectly flat curve would be 3.44cu/ft tuned to 27hz, so the ripple is very very small. Most woofers need a stupid large box and low tune to get a flat response curve. My Boston G5s are tuned to 33hz and have an fs of 28hz and I can play down to 20hz without unloading and my sharp rolloff begins around 25hz. According to winisd my f3 is 33hz.
kthxbye
What did you mean by that sentence? Lol
I'm beginning to think a single sub might not be such a bad idea. I have a 2009 WRX and so it's not in a trunk, it's in the cabin area (the whole car is connected). The problem is I just sold my 400 watt memphis audio sub powered by an Orion Cobalt amp because I just wanted a little bit more of a prominent bass, but if I just get another single 12 inch again I feel like I won't have gained anything, just lost a bit of money. But the cabin space IS somewhat small, maybe I can figure something out that works well.Sorry, on my phone at the moment.
I would set a total budget. One that will cover your amp, sub(s), enclosure, and anything else you may need.
Then start to look into what fits with in your limits. To be honest it sounds like the budget may be a little tight, so looking into a single 12 ported with decent power may be a good option as well.
I'm actually the owner //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif... lolI'm beginning to think a single sub might not be such a bad idea. I have a 2009 WRX and so it's not in a trunk, it's in the cabin area (the whole car is connected). The problem is I just sold my 400 watt memphis audio sub powered by an Orion Cobalt amp because I just wanted a little bit more of a prominent bass, but if I just get another single 12 inch again I feel like I won't have gained anything, just lost a bit of money. But the cabin space IS somewhat small, maybe I can figure something out that works well.
So you work for a company that sells boxes, how much would I be looking at for a single 12 inch ported box at around 33 hz?
I will go measure my trunk area, hold on 1 minuteI'm actually the owner //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif... lol
I would say before we go into quotes, the best option is to measure the area you would like to utilize for an enclosure. Then we can see what kind of space limitations we have to work with and figure out what will best work for your application from there.
As for the single sub. If you had a "prefab" enclosure with that setup, you will find that using a better quality 12 with a custom enclosure will net much better results per dollar spent. The equipment is important the but the install and enclosure make a huge difference in how it will perform in your application.
