Sealed Box Volume - Blaupunkt GBW101 10" SVC 4ohm
Southern_Exposu
29
Boise
I grabbed a few of these a year or so back when Walmart had them for $20. I got some good help for box design for a ported enclosure.
Well that was fun for a while but I need something smaller and honestly prefer the less boomy tight punch I get from sealed. And honestly
size is the biggest motivator.
But, I can't find any recommended sealed box specs for these. Going to try and make something that will fit under the rear seat of my Avalanche.
I'm thinking something around .75 cu ft. Below are the only specs I have (center column GBW101). Thanks for any help.
26850
Figures. I can't do the big box anymore. We cut down from 3 to 2 vehicles and the space is needed too often. Any recommendations for a cheap single 10 or 12 that works in small spaces. I was pretty impressed with those cheapo subs. and by cheap I mean less than $100
I saw a buddy of mine pick up an infinity reference 12 for I believe $70 he ran it in a small sealed box and it sounded pretty good. Nice tight sound quality and pretty efficient for a 12
Slightly over your 100$, but small, 10, and cheap don't usually go in the same sentence.
Only needs .45 cubes, and I've heard it sounds good sealed.
What he said... Any damping of over 80 is fine, 200 is really good, so 1000 is like my 80lb home audio amp! Unless you are using certified Hi-res...
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
If you experience any air leakage from the screw holes.. adding Clear or the color of you choice of Silicone works just fine after a 24 hour cure...
10
Stereo Integrity hst12, only needs .6cuft after displacement. I have mine in a 15 inch double wall birch ply cube, .55cuft after displacement...
Most ported boxes will be 1.75-2.5cubic feet of airspace. That's just a base requirement. Sealed will be .8-1.25. That said ported has the...
Southern_Exposu
Southern_Exposu
Boise
LsGuy
    Apr 26, 2024
    Apr 26, 2024
