Sealed Box Size?? Bigger Better??
  • 2
outer dimensions mean very little, give us airspace....
bigger is better toa point..
larger boxes will give you flatter response, more low end extension, but will also reduce the power handling of the driver..
be careful not to go TOO big, as that will cause an infinte baffle situation...
yes, but then teh enclosure itself would be the limiting factor...
if you were meaning to achieve an infinite baffle situation, you would noteven both with a full enclosure and use the trunk itself as teh 'enclosure'
i would doubt it....
if they let water in, teh body decomposes faster //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I dont think this forum is letting that link work. It keeps changing it to a link to this forum. Try this. Just change the dot...
10
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
If you experience any air leakage from the screw holes.. adding Clear or the color of you choice of Silicone works just fine after a 24 hour cure...
10
Stereo Integrity hst12, only needs .6cuft after displacement. I have mine in a 15 inch double wall birch ply cube, .55cuft after displacement...
Most ported boxes will be 1.75-2.5cubic feet of airspace. That's just a base requirement. Sealed will be .8-1.25. That said ported has the...
Miller
Miller
Chicago,IL
Wonderbread
    May 16, 2024
    May 16, 2024
