sealed box hole
  • 4
klepto
Perveyor of Filth
i have a sealed box, and there is a little itty bitty whole in the side of it about 1/2-3/4 mm in the side to let the cables pass out. now be aware, the cables are a VERY tight fit in this hole and not much space is left. is this bad to have a lil opening like this?...the opening is VERY small. and if not, what can i use if anything to seal it
ANY air leak is not a good thing. Your box should
be as tight as possible. I have my speaker wires
run through a hole cut out in the box. Like you've got.
I used Liquid Nails on both sides to seal it up.
I dont think this forum is letting that link work. It keeps changing it to a link to this forum. Try this. Just change the dot...
10
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
12
If you experience any air leakage from the screw holes.. adding Clear or the color of you choice of Silicone works just fine after a 24 hour cure...
10
Stereo Integrity hst12, only needs .6cuft after displacement. I have mine in a 15 inch double wall birch ply cube, .55cuft after displacement...
7
Most ported boxes will be 1.75-2.5cubic feet of airspace. That's just a base requirement. Sealed will be .8-1.25. That said ported has the...
klepto
Perveyor of Filth
klepto
San Jose, CA
FiendAZ
saints747
    May 7, 2024
saints747
    May 7, 2024
Latest topics
