SAZ3500 problem need help asap.....
dasinde91
TEAM SUNDOWN
I am currently running 3 nightshade 12's with 2 saz3500d's.. ever since i put in an odysee 2150 battery its been putting my slave amp (2x 3500ds Sundowns) into protect mode, and it will not restart it stays in protection. Any help would be greatful. This is the second amp its done this too, am im completely clueless.
Thanks,
Scott
electrical is completely factory other than a optima red top in front, with the odysee in the rear, we have 8 runs of 0 gauge from the back to the front. I'm not sure if everything is paralell, the subs are wired to 1.3 ohms, and hooked up that way. Thank you guys im just seriously confused as this is the second amp thats took a **** from this and im not sure why..
so your runnin 7k watts on a stock alt and 1 odysee wow //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
yes I have aim @ sinde91, and yes im running the stock alt on all this, for street c... Anything u guys need to know just ask, i feel like such a **** right now but i really dont know what else could be the problem other then the batttery.
Read his post man! it's for street c, which has battery rules. What's your voltage drop to??
So just how low does your voltage drop? How hard are you beating on this setup?
You need a much better battery up front. Disconnect everything but power & ground from the amp that's in protect and see if it comes out of protect. If it's blown post up pics of the inside.
where does it say anything about street c besides his sig?
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
598
https://www.caraudio.com/threads/all-bnib-focal-fdp-4-600-ds18-exl-p2500-1-sundown-audio-sfb-1000-4d-350x4-4ohms.614462/ :)
18
735
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
516
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
dasinde91
TEAM SUNDOWN
dasinde91
Chicago, IL
audioarsonal
    Apr 28, 2024
    Apr 28, 2024
