SAZ-1500D Protect Light Coming On, but not going into protect....
timma100
Noticed it as soon as I hooked it up. Takes a couple minutes of bass, then the protect light starts to come on and off. Then it goes on solid and stays on, but I can still play music just fine, the bass doesn't seem different. The amp is getting stereo input from the deck, don't know if that matters.. I don't really know whats going on... My first guess is its not getting enough amperage.
take a voltage reading at the amp power and ground terminals with it off, on, not playing, and then playing and when it protects. also, ohm the speakers.
The speakers are two dual 4 ohm subs, wired to 1ohm but they are 1.4ohm on my DMM
I still have my old cap hooked up, the voltage on the cap display is 14.2 and dips to 12 at the worst. But I think the cap is just bumping voltage up, but there isn't enough current on the line to supply the heavy loads. I haven't had a chance to redo my electrical system yet, and I am getting huge headlight dimming. I believe the main line from the batt is 6awg but I don't know for sure, il dig around and check it today when I get the voltage readings. If the amp is in any danger what so ever, or if its just not good for it, I wont hesitate to go back to my Xplod until I get a proper electrical system. Its stock batt, stock alt, 6awg main power line, and a 2ferrad cap (not like it does anything for an amp of this size) But then again I don't know what im talking about so who knows
Il post the rest of the info soon
The speakers are two dual 4 ohm subs, wired to 1ohm but they are 1.4ohm on my DMMI still have my old cap hooked up, the voltage on the cap display is 14.2 and dips to 12 at the worst. But I think the cap is just bumping voltage up, but there isn't enough current on the line to supply the heavy loads. I haven't had a chance to redo my electrical system yet, and I am getting huge headlight dimming. I believe the main line from the batt is 6awg but I don't know for sure, il dig around and check it today when I get the voltage readings. If the amp is in any danger what so ever, or if its just not good for it, I wont hesitate to go back to my Xplod until I get a proper electrical system. Its stock batt, stock alt, 6awg main power line, and a 2ferrad cap (not like it does anything for an amp of this size) But then again I don't know what im talking about so who knows
Thats probably a good idea. I bet your voltage is dipping pretty low.
Played "Beats 4 my van" today, smelled the glue burning. Saved the subs, rewired them to 12 gauge series and went back to my xplod. Almost lost em Q_Q
I wish I were trollin lol. I have the amp set to 34V on a 1.4ohm load. so ~900W rms. I could smell the subs, went back to the xplod 500RMS same song, over heated the subs. Only explanation is the song hits to low, over heating the subs.. no subsonic on the xplod. so no playing that song
As title. Once i get to about 4/5 max volume my JL HD600/4 amp goes into protection mode on 2 channels, powering my mids. The other 2 channels...
Not sure If I can Help you fix the issue without being present.. But the first thing i would do is remove all RCAs and All speaker wires from the...
maybe bad amps. I would purchase a decent amp off of Amazon. They usually arrive in 2 days if you have "Prime." If the problem persists, you can...
You don't understand understand brazilian amps and how finicky they can be about voltage...everything you just said nonsense
13
timma100
timma100
Barksdale AFB
timma100
    Jun 1, 2024
    May 31, 2024
