Same tweeters, different brand?
adulbrich
Olive oil un-virginer
14,433
123
Ames, Iowa
I was looking for cheap tweeters and saw these:
Power Acoustik NX-5 Pro Audio Bullet Tweeter - Sonic Electronix
WoofersEtc.com - 15-MJPT - Memphis 1" 200W Max Aluminum Frame Bullet Tweeter
Power Acoustik: $48
Ohms: 3
frequency response: 3,000-20,000
Memphis: $130
Ohms: 4
frequency response: 2,000-20,000
They look identical, except for the top mounting rings. RMS is also the same (100w). The price is really different. I didn't know if you were just paying for the Memphis brand.
I know most people don't like the sound of bullet tweeters..
I was planning on using them in an active 3-way front stage. Thanks!
Open tooled frames are very common in speaker manufacturing in order to lower costs. What looks like the same driver with a different brand name may sound very different.
I was just wondering, because the magnets are the same too. I figured the price was too different to be the same product.
As far as cheap tweeters, how much does it make a difference?
For the bullets check out the Pyle's on PE, same tweeter as you listed. I've run those in a few set ups, can get VERY loud. Do NOT mount them on-axis....
what's the rest of your front stage consist of. Unless it's several a LOT of mids you'll never approach putting anythign but a few watts on those bullet tweeters. Don't worry about yrou amp size because you still have to level match everything to your weakest link, unless you want your treble 2x as loud as everything else. RMS on tweeters is a pretty moot point unless it's for an actual pro audio build or 150+db bassracing style dialy. Even then, for high effeciency ones, still isnt' an issue.
Anyways someone mentioned they pyle pro bullets and all the pyle pro gear I've used has been very impressive for it's price point. I'd try those.
I doubt that you will be giving the tweeters that much power. As stated above, once you level match your drivers things will be fine. It doesn't take a whole lot of power to get the tweeters loud.
I understand that, but I'm trying to find what frequency I should cross them over at. I know there is a lot of play with the blending of mids/tweets in an active system. I'm thinking about starting at 3k hz, and going from there
I'm using the 8 ohm pioneers from my for sale thread as mids. They've got a really cool suspension imo
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
744
To add the tv, I got a second deep cycle battery, ran thick cable from my starter battery to the deep cycle battery(or you can run to a dc to dc...
I don't think it's that easy to answer "for a complete beginner". amp and speakers ratings are those peak or RMS? Are these already installed...
No different than powering multiple amps. I'd use a fused distribution block. Power each amp. Probably easiest to just add that to the existing...
DJ subs are designed for efficiency, car audio subs are designed for low end in a small space. So above ~50hz the DJ sub will kill a car audio...
adulbrich
adulbrich
Ames, Iowa
ThatChevyGuy
