Running on speaker leads?
smakrabit
I'm helping a friend with an install, and I've ran into a situation that I've never incountered before. He wants to keep his factory head unit which has no rca outs. Can I run from the back 6x9 speaker wires into a converter box into to the amplifier or will I have to disconnect the back speakers to use them for the amplifier signal? Also, how can I find his "rem" wire to come from the head unit to his amplifier?
Smakrabit
well you could do the thing w/ the 6x9's and the remote wire is usually the power antenna wire.....so use that if you can find it or use a wire that comes on when the acc comes on.....good luck
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
485
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
Thanks for the feedback. It was a long shot but there will definitely be much more powerful subs in the trunk, so clearing it out isn't an option...
smakrabit
smakrabit
Kansas City Mo
maylar
    May 18, 2024
    May 16, 2024
