hemi=22s
I Pop Bottles
- Thread Starter
- #16
i will have 100 watts rms to the rsds eachOverkill is an understatement, unless you are powering a shit ton of them off a huge fawking *** amp.
I think you should tone it down some and run 2 sets in each door and would do just as good if not better.
Also, if you want to not go active, then mount them in the back of the wall.
How many subs are you running?>
i will be running 4 re mt 15"s 2 each off a mmats 4000.1 may switch to new btls in the future tho
also where can i get a 15 raw screen, i want to put this in the dash and my 980bt in the center console
And i decided to change the design a lil bit, im going to put 1 set in the kicks, 5 in the front door, and in the rear doors and one in the back where the amps are going since i will have a lot of open room behind the wall to fill in
