DJItalianICE
Can I run my amps in parallel for the positive side? You know, one 4ga to one amp, then 4ga from the + of that amp to the + of the other amp. Will it work better than a non-fused distro block?
Or should I just run two seperate wires from the inline fuse holder in near the battery?
Also, is it OK to run power wire parallel with RCAs? Would that cause alt. whine?
