RSD comp wiring question
bsean63
Undead Revolution
ok fellas, ive been looking for a spot on my door to run the wire through and find nothing, i was just told to use the factory wires to connect to the back of my speaker and then cut my front left and right positive and negative wires from the RADIOS harness and then run that to the crossover....... Any suggestions on this???
also ive been loomking for a spot to mount my tweers, and Crossovers... i think im gonna mount my crossovers in the trunk but what about the tweeters???
thanks fellas
A-pillars work well for mounting tweeters, or somewhere in the door. Often times cars have a plastic piece near where the side-view mirror is that works well also.
running them through amp, guess i shoulda said that..... and factory molex has a big *** Plastic clip in it covering the whole hole
yeah my car has that, so that means i would have to cut holes? OH NO that wont be good, lol
u can put the xovers anywhere u want if u put em by the amp u gotta run twice as much wire, up front gotta be careful they dont get smashed or wet.
drill out the factory molex in the blank spots to run wire thru em
i mounted my tweet on the a pillar with the cup mounts used 1 small screw so there ia a small hole in each piece but i have a new car
depends on if u wanna cut the car or not, if u do decide to use a hole saw with the diameter pg gives ya for the mount diameter its pretty easy the bit fits in a drill and makes perfect circles
**** im scared to do that shit, ill try n drill through the clip and pray i dont **** anything up
cool but would what i asked in the original post work, ya know just in case;)
yeah that would work, but i never recommend cutting the factory wiring, if u do it that way make sure the wires are disconnected behind the radio and cap em
then use t-taps to tap in to the factory wires in the kick panels on each side
i got ya u could do it that way, kinda ghetto but **** it no one will see it
lol no kinda to it, straight ghetto, but you said it "no one will see it", **** it im goin to try it the better way then if all else fails GHETTO:)
ah why not as long as u got tight connections and u crimp off the stereo speaker outputs fuk it, u wont get an audible difference out of it and it will be easy but i recommend the right way lil molex drillling is easy stuff as long as u dont use a bit bigger than the hole:laugh:
wait til ya see the contraption im have to make to get 12 12awg wires in my doors for my comps //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif i am gonna have to make something
bsean63
Undead Revolution
bsean63
ohio
bsean63
michigan born
    May 14, 2026
michigan born
    May 14, 2026
