Rockford Fosgate T2s? or JL Audio W7s?
Swiferman87
In the next few weeks i plan on buying a major car audio system. I plan on buying it at Woofersetc.com since they seem pretty reputable and they don't seem to good to be true.
The Vehicle I'm getting has quite a bit of room. Here are a few questions i need to know.
1) 6 Rockford Fosgate 15" T2s? OR 6 JL Audio 13.5" W7s? Price doesn't matter since i'm getting a large loan to cover it all.
2) What Brand of High Output alternator should i get?
P.S. The Vehicle is a rebuilt GMC K-something Blazer, i saw it today and test drove it and have to have it he only wants 5,000 for it...which isnt bad considering it has a rebuilt 454 and radiator in it, it is also in pristine condition.
neither. JL are not worth the price. fosgates are eh... nothing special. at all.
for the price of each sub, go with AQ HDC 15s or 12s.
maybe some TREO subs, Sundowns, RE XXX
If I had to pick one, deff the W7s. But I would choose something diff. Those are 2 very different style subs. You need to figure out what your goal of the system is. I course we see you want a lot of sound, but do you want SQL, SPL, more SQ, etc...
I would not get some Audioques as stated above. I would look into some Treos, though, some Sundowns, but I think the new SSA ZCONs or even the new SSA XCONs, would suit you best. You could run 4 15s and deff out-do those other set ups.
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
Swiferman87
Swiferman87
Helena,MT
09civic
    May 16, 2024
    May 16, 2024
