rockford fosgate power t142
playyamxz550
Memphis
I just bough 4 rockford fosgate power t142 so 160rms total. Im looking for a small 4 channel I wanted to go rockford but smallest power I see is 400rms and smallest punch is 400rms also. Is there any older model rockford fosgate amps I should look for or is there smaller rockford amps?
that amp will probably do close to twice that..
i have a rockford fosgate power t500-2
rated 75x2 at 4
does about 300x2 at four
1000 at 2 bridged
1300+ at 1 bridged.
it wont be too much, just keep the gain way down
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
playyamxz550
playyamxz550
Memphis
playyamxz550
