Rockford Fosgate power hx2 help
Sspider
I have a question. I have just bought one 12" rfr 3112(power hx2) It has 2 2ohm voice coils. now my question is, how do i wire them for 2 ohms???
I was told you cant wire them for two ohms. only 1ohm or 4ohms. I bought the rockford bd1000.1 amp to power the sub. it gives off 500 watts at 4ohms but i want to give them the 1000watts the amp gives at 2 ohms.
you can wire them at 2 ohms you wire the positve of one vc to the negative of the other and run you r power to the positive of the firts and the negative to tthe other vc. its hard to explain hope it helps if i had a pic of it id send it to ya
doesn't that make it a 4 ohm load? here is a diagram is dat how it is?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif :confused: //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
ok i got it, i have the sub wire for 1 ohm, but my problem is that i dont want to damage the amp by having the sub at 1 ohm. I have the bd1000.1 amp. Can it handle a 1 ohm load. Need help before i blow things and waste my money...//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
Sspider
Sspider
new york
Sspider
Jared Schwersky
    Jul 19, 2026
Jared Schwersky
    Jul 19, 2026
