Rockford Fosgate 1200D PROTECT MODE!
Duedle
I have this weird scenario that whenever my vehicle is turned on and in park my amp has a blue light on meaning it is working, but whenever the vehicle is either moving forward or going in reverse the red protect light starts blinking. I has 2 Rockford Fosgate P3's in a ported box wired to 1 ohm and i checked the terminal cup resistance and it is in fact wired to 1 ohm but i cant figure anything else out that can be causing the amp to enter protect mode while moving?
Check the voltage reading while in drive or reverse.
Sounds like voltage is dropping to low or going to high
Sent from my SM-N950U using Tapatalk
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
Duedle
Duedle
Tampa, FL
Boomin_tahoe
