review my first system :)
if i was u i would go with sonicelectronix.com......and keep both subs.....and go with this amp
http://www.millionbuy.com/prfap2000.html
this will make those cvrs move for sure.....and then save ur money to get the other stuff but i def. would jump on that offer for the cvrs.
That's a great suggestion. //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
please review. also please make sure my amp and sub will go together well.
sub (getting only 1 for now):
http://www.millionbuy.com/kik07cvr122.html
amp:
http://www.millionbuy.com/prfap1000m.html
wiring kit:
http://www.sonicelectronix.com/item_7575_American+Accessories+Power+Kit-8.html
line out converter (for my 99 taurus & stock HU):
http://www.crutchfield.com/S-X4Al7SY8SZf/cgi-bin/ProdView.asp?i=142SLC4&tab=morephotos&s=0&cc=01&g=721#morephotos
box:
http://www.sonicelectronix.com/item_7681_Sonic+Sub+Box-+1SL12-1.0+-GRAY+CARPET-.html
thoughts? am I missing anything? I want to order everything and get it all hooked up the day it comes.
thanks!!
Thats a pretty good budget system if you stick to one sub lone config. You sure you dont want to go with a ported box for more spl?
I'd say so. Get two 4-ohm CVR's and wire them down to 2 ohms. The Profile amp you gave us a link to should handle them both fine then.
two DVC 4 ohm CVR's will go to either 4 or 1 ohm..not 2 ohm //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
if you want to run it at 2 ohm, you need two DVC 2 ohm CVR's, if im not mistaken, CVRs only come in DVC and not SVC.
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif one dual 4 ohm sub can be wired down to 2 ohm.....so all u have to do is do that to each sub and then if u get a 2 channel amp just wire each sub to a channel.
http://www.rockfordfosgate.com/rftech/woofer_wizard/1_4ohmDVC_2ohm.gif
Yeah, I thought about that before I went to sleep last night. lol... oops. Either way, I don't *think* the 2 ohm CVR's are any more expensive, so he should be fine doing exactly as you said.
True, however, he is purchasing a mono-block if he goes with the Profile.
I decided I'm going to buy the 2 CVR's from either crutchfield/soundelectronix and sell one of them (I may end up keeping both though haha). I am also going to hand build a ported box. And I like the profile AP1000/AP2000.. so I'll probably get one of those.
Thanks for the help fellas.. any other suggestions let me know.
js09
js09
Columbus
js09
