Resko1's Team Sundown Metro build
resko1
<<< 8" TC1000 LMS S3
1,154
Sheboygan,WI
K. guys. Heres whats going on. Have a 98 Chevy Metro. POS! hoping i can blow it apart. Build is an Eclipse CD7000 HU, O.S. US Amps usa200x for the front. CDT TW25 and TW23 tweets. Currently using CDT M6's for mids but most likely i will be switching them out for 2 pair of Aurasound NS6's. 4 C&amp;D 12-350 batteries multiple runs of 1/0 and 2/0(for the amp). Sub stage will be 8 Sundown SA8 D4's powered by an Atomic AT-7000.1D @ 1ohm.
Here's the car
The doors as they are now.
Moofers!!
And teh powa!!
Front amp is under the drivers seat. Tiny amp, but puts out harder then a ***** on the corner in NYC! for real! rated 100x2 @ 2 ohms, 12v.
Started some wiring too.
copper bus bars
charging the c&amp;d's
Short runs done. 2 runs of 1/0 from front to rear batts. Each rear battery will also have it's own 1/0 ground directly to the frame next to it. All lugs are soldered on with a torch.
Removed the back seats and all the trim panels today for deadner. Cut the box od out of cardboard to test fit. Fits perfect! Also test fitted the amp and it too fits.
Now comes the real work! deadner, build and install the box, wire up the batteries and amp and i should be set!
Props to Team Bringing the bass for the help.
Me likey //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
A USA 150x would be even better.//content.invisioncic.com/y282845/emoticons/boink.gif.91933e72f927f2cefc79aff02573090c.gif
Lol, I just got moolah for it =] Sold it for more than I paid for it =[ Sorry =[ What about a linear power 901? =]
tuned in! btw, threw in a 6" aero this weekend on the 4 8s and tried tuning it low under 40 and sounded like chit....was 13" from flare to flare..about 36-37hz...beat the lows really good but fell off on higher frequencies....took out the middle section and just taped up the flares together....about 6" flare to flare and sounds good but seems like i got more output with the 8" aero...still need to get my hands on my buddies TL to see how they compare meter wise
Uggh. No linear power. Louisiana CRX was suppose to sell me a second 200x but he fell off and never contacted me again! //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Hmm. Im thinking its as i expected with the ts parameters. The 4th order would make an excellent fart box, but for daily or streetbeat i dont think it would cut it. Im gonna stay ported. 6cu tuned to 30-32hz.
359
10
My wife is gonna sh!t bricks when my subs get here. She doesn't know yet
19
resko1
resko1
Sheboygan,WI
resko1
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
