Replacing stock speakers in Passat B6 2005.
lifefromelvis
Latvia
Hello ,
I need your advice / suggestions. I would like upgrade my stock speakers to new speakers , but don’t know which speakers choose or maybe need to look for something else. But , I don’t want to use amplifier and subwoofer , only good speakers to make good music with good quality and bass in a car.
I found two options .
1. https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F371790073294
2. https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F263336487339
3. https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F262785265982
How do you think , it’s good ? Any suggestions ?
I am using MFD2 player and old blaupunkt speakers .
Really ? nobody ? :/
Your not gonna get better quality and better bass from just changing speakers.
It may sound a bit different and a bit better but not a huge difference.
A amplifier will be needed for more bass, keep the same speakers and all that you have and find a dsp that will work on a stock system instead.
Sent from my SM-N950U using Tapatalk
You really dont know how car audio works, changing speakers wont do jack sh*t for your setup. You are better off amping your stock speakers. More than likely you'll get worse sound than your stock speakers if you dont know how to deaden and recreate the factory baffle.
Its never justifiable to rush a clean install. Its best to do research for the proper speakers needed and wanted and amplifier to supply for the...
37
6K
At the end I decided to take the dashboard out, since I also had to solve a problem with the heater core. Upon inspection, I could not find any...
10
lifefromelvis
lifefromelvis
Latvia
Jeffdachef
    May 24, 2024
