Replacing Door Speakers - Range Help!
zoltman1991
CarAudio.com Regular
Hi there!
I have a 2020 Lexus ES350.
I plan on replacing two front 3.5"s and two door 3.5"s and two front door 6x9s.
Right now, I have an ACX650.5 and I plan to run 50 watts into the four channels, then wire two SVC4ohm 6x9s to a 2ohm load on the 5th channel (full range outputs).
ALL KICKER KS series.
I swapped the 6x9s into the door, but I realised the factory amp was only sending low frequencies, so effectively was acting as a mid-range subwoofer.
My questions are:
-when I install, which speaker inputs should I use for the ACX650.5 to ensure the 6x9s have full range?
OR is it better to get the LC7i (I have a subwoofer set with JD1000.1, so then I can run the speaker inputs and have the 'sum' setting selected for the outputs on the 6x9s?
My reasoning is that I bought the KS 6x9 because I wanted better mids and highs, so I want to send them full frequency ranges.
I put myself in a pickle and thinking I may need to drop the ACX for a 4-channel amp and a 2-channel amp (likely Alpine A32 and Punch 500.2). This would force me to get the LC7i.
I assume that the system has a factory amp somewhere? They have to hi-pass the 3.5's to keep them from blowing out, and they low-pass the 6X9's as you said. If you want full range you'd have to tap into the front HU outputs before the factory amp.
My questions are:
You tap into the 3.5s and the 6x9s then use the summing feature. This will sum the 3.5 and 6x9 frequencies into a full range output.
zoltman1991
zoltman1991
houston
1aespinoza
