Replace factory unit but keep factory installed Sirius
comrade
Are there any aftermarket stereos that I can put into a Chrysler T&C van, that will plug into and allow the use of the factory installed Sirius radio?
The factory stereo is pretty bad, and I'd like to replace the stereo and speakers, but I'd still like to keep the Sirius radio that's installed. It also has the steering wheel controls, a six disc changer that's separate from the head unit and a couple of overhead video screens.
I've had the overhead video in the last couple of vans, and I've never used it. I could just disconnect all of the video wiring, but I'd still like to keep the steering wheel controls and if possible, still have it work with the disc changer.
Are there any units now made that will work in this application? As I said, the factory stereo is quite bad and I've always had good luck with Alpine units in my last couple of cars.
Any help would be appreciated.
Thanks!
Theres not much you can do to replace the HU and keep the factory sirius. I would just keep the factory HU and use a LOC to add a 4 channel amp and speakers. That should keep all the features you want and still give you great sound.
You will be able to use the factory antenna for sirius and get an aftermarket sirius control for your alpine. There is an adapter for steering wheel controls but you may be out of luck on the changer.
comrade
comrade
Chicago suburbs
comrade
