Removing wires/pins from Pioneer harness
  • 6
mstrjon32
Hello all, I'm installing a Pioneer PRS80 and I'm trying to remove the speaker wires from the harness, since I won't be using them. I'm not sure how to get these out and I've already spent considerable time messing with it. I'm assuming that I must somehow release the clip from the front, in the center part of the connector, but I just can't get them to let go.
If anyone has done this before, any help would be appreciated. I hate to have unused cables cluttering things up.
You must understand, I am quite pedantic about these things.
It should be possible to release the wires from the connector in such a way that they could be reinstalled later. It's quite straightforward with the "molex" style connectors, they can be snapped in/out of a harness, but I'm not sure about this connector from the Pioneer...
CRXBMPN: Thanks for the link, but that seemed to be a different type of connector. On this one there doesn't seem to be any way to push from the top to loosen the pin.
I had some dinner and a few beers and came back to it, only to break one of the pins. With that out of the way, I just went ahead and pulled the rest of them out using a pair of pliers. Little buggers, glad to have them out of my way!
If I was in your situation, I would experiment with the wring for a day or two. If that didn't work, I would purchase an external amplifier. Run...
I didn't read the article, but with those GM Bose systems; either fix what needs fixing, or rip out the entire thing and start from scratch with...
Try placing the subs in the front seat, to see if the issue persists. Just for diagnostic purposes. It may be wiring, but the distortion may be...
953
mstrjon32
mstrjon32
Mainz, Germany
trumpet
audiobaun
    May 19, 2024
    May 19, 2024
